See attached screen shot and qcad pro dwg file. I've trimmed the walls (in yellow) in this one section of walls including ends. the screen shot shows in dark red the completed section yet when i click to the inner part it still dosent hatch. Help help, thanks, Danny
Version:
3.21.3.0 (3.21.3)
Internet:
QCAD.org
Build Date:
Sep 17 2018
Revision:
4b91c8c
Qt Version:
5.5.1
Architecture:
x86_64
Compiler:
MSVC++ 12.0 (2013)
[solved] Still cant hatch???
- qcad cant hatch.JPG (88.18 KiB) Viewed 2557 times
- Trimmed walls yet cant HATCH DWG V5 Plans.dwg
- (126.05 KiB) Downloaded 299 times
Re: Still cant hatch???
This seems to work fine here.
Please let us know how you proceed step by step, what tool(s) you use, etc.
Here's how it worked for me:
1. Select the wall outline (8 lines)
2. Draw > Hatch > Hatch from Selection
3. Choose pattern or solid fill, etc.
4. Click OK
4. Click OK
thanks. the tutorial shows to select it after bring up the tool, this way it works
