I assume there is no possibility to add some additional informations in a symbol which I don't want to get visible in the drawing?
I thought of something like "standard delivery with 1 x 150, 1 x 100, 1 x 60 cm safety fences" - a simple textblock which could be visible in the properties editor.
Additional informations in library items
- Senior Member
Best Regards
Sven
QCAD 3.27.6.0 / Windows 11 Professional 64-bit / 16 GB RAM, i5 [email protected], SSD
(former Autosketch 10 user)
Sven
Re: Additional informations in library items
Yep - there are only limited possibilities. Whats about to misuse the Custom Property's (Property Editor) or to use a Layer which is normally switched to invisible?Rantanplan7 wrote: ↑Thu Oct 04, 2018 7:49 amHi,
- Senior Member
Just tried it and yes, the property editor is a possible solution for this, thanks.
Best Regards
Sven
Sven
