Cant get drawing to align to grid or snap to align to drawing
vdanny
Post by vdanny » Fri Oct 05, 2018 8:22 pm
Cant get drawing to align to grid or snap to align to drawing, see attached. I have to free snap making difficult to align to the line (ie, a wall line to another wall line). When I try to snap to it, it doesnt align.
Help, Thanks, Dan
QCAD Professional
Version:
3.21.3.0 (3.21.3)
Internet:
QCAD.org
Build Date:
Sep 17 2018
Revision:
4b91c8c
Qt Version:
5.5.1
Architecture:
windows 7
x86_64
Compiler:
MSVC++ 12.0 (2013)
Berg Boone St DWG V6 Plans.dwg
(239.59 KiB) Downloaded 271 times
Re: Cant get drawing to align to grid or snap to align to drawing
Post by Husky » Fri Oct 05, 2018 8:55 pm
please double-check your Auto Snap settings and then make sure Auto Snap is switch to ON.
vdanny
Re: STILL Cant get drawing to align to grid or snap to align to drawing
Post by vdanny » Mon Oct 08, 2018 6:42 pm
My auto snap setting ARE ON. Here is screen shot (center points and points on entry are the only ones not on). I included my DWG QCAD PRO file so someone can tell me why this isn’t working correctly.
The lines or objects are snapping to the grid yet they aren’t aligned to what is on the drawing.
IN other words the drawing isn’t aligned to the grid and therefore when I add a new line, it doesn’t align or snap to existing, and instead it snaps to the grid, which isn’t in alignment with the drawing. I can free snap, yet then its alignment is very time consuming to get accurate.
Also when drawing a line vertically or horizontally it wants to snap to the grip and the end of the line or start at a grid point that don’t align with the existing drawing
Post by Husky » Mon Oct 08, 2018 7:18 pm
The attachment is missing.
