Is there a way via Keystrokes to access the command line?
If I have selected an object, like a line, with the mouse. and now want to use the command line to tell it what to do. Is there a keystroke to bring up the command line without moving the mouse pointer and clicking on the command line? before entering the command?
Qcad version 3.21.20
Windows 7
Accessing the Command line
Re: Accessing the Command line
Try the "Space" key on your Keyboard ...
See also shortcut list at:
https://qcad.org/archives/shortcuts/shortcuts_en.pdf
You can also see the shortcuts in the menu, this one's under View > Focus on Command Line.
Thanks for the quick response
