Printing Problem White Paper
mlwoy
Post by mlwoy » Mon Oct 15, 2018 10:47 pm
I am having problems printing. I select what I want to print, set the print area, have all of the layers chosen, the print preview screen shows the area. Then when I tell it to print, and select print preview in the print setup for the printer, tell it to print and it comes up with a white piece of paper with nothing showing to print. Occasionally it will show something to print and that is what I get.
What setting is causing the print preview screen to come up white and print nothing?
Operating system Windows Seven
Qcad version: 3.21.2.0
Oh and I have checked out the help system and referred to the manual and no help there.
Re: Printing Problem White Paper
Post by andrew » Mon Oct 15, 2018 10:58 pm
You can find a detailed step by step printing tutorial at:
https://qcad.org/en/tutorial-printing
If you still experience problems, please attach your file.
