Calling a variable from another js file
woddy
Post by woddy » Fri Oct 26, 2018 12:52 pm
Greetings again,
During scripting i noticed that my 1.js script is quite long and since its hard to follow, i want to do some calculations that i currently do on 1.js in 2.js
I used export/import from ' ' statement but couldnt manage to send the variable 'first' under prototype.beginEvent in 1.js to 2.js
I wonder if there is a way to send a non global variable to another file do some computations and call it back to the original file.
I hope i made myself clear. Thanks a lot
 // 1.js
1.js.prototype.beginEvent = function() {
var first = 10;
import {second} from './2.js'
 //2.js
var second = 5 + first;
export { second };
Re: Calling a variable from another js file
Post by andrew » Fri Oct 26, 2018 1:04 pm
To include a script, use:
include("scriptfile.js");
usually at the beginning of your script, see examples at:
https://github.com/qcad/qcad/tree/maste ... c/Examples
To pass variables around, you'd typically use functions:
function myFunction(myVariable) {
   // do something with myVariable
   // return some result:
   return 7;
Again, please refer to example scripts.
If you are creating an interactive script, please start with this tutorial:
https://qcad.org/en/tutorial-interactive-script-actions
