importing 3 dxf files to blocks
dobidobido
Post by dobidobido » Fri Nov 02, 2018 4:55 pm
Hello im curious if i can import three dxf files on seperate blocks by using import file. I ve checked paste,edit and import scripts and wrote the below code,
   var sourceDocument = RDocument.getClipboard();
     var sourceDi = new RDocumentInterface(sourceDocument);
     var offset = new RVector(0,0);
     di.setCurrentBlock("D1);
     var op = new RPasteOperation(sourceDocument);
     sourceDi.importFile('a.dxf')
     op.setOffset(offset);
     di.applyOperation(op);
     di.setCurrentBlock("D2");
     var op2 = new RPasteOperation(sourceDocument);
     sourceDi.importFile('b.dxf')
     op2.setOffset(offset);
     di.applyOperation(op2);
     di.setCurrentBlock("D3);
     var op4 = new RPasteOperation(sourceDocument);
     sourceDi.importFile('c.dxf')
     op4.setOffset(offset);
     di.applyOperation(op4);
it basicly puts a.dxf on block D1, a.dxf & b.dxf on block D2 and a.dxf,b.dxf and c.dxf on block D3 however i want a on D1, b on D2 and c on D3. I know i need to change sourceDocument each time a file is imported but i couldnt figured it out. How can i change the sourceDocument so that the previous imported file is not imported on the current Block.
Thanks and apologies for taking your time.
dobidobido
Re: importing 3 dxf files to blocks
Post by dobidobido » Fri Nov 02, 2018 11:04 pm
Briefly, i mean how can i implement deleteClipboard operation? is there any examples sample scripts using it?
dobidobido
Post by dobidobido » Sat Nov 03, 2018 12:57 pm
any help or update?
Post by andrew » Mon Nov 05, 2018 12:11 pm
I'd recommend to create a separate offscreen document for each item:
var sourceDocument = new RDocument(new RMemoryStorage(), new RSpatialIndexSimple());
