Order of attributes in drop down menu when inserting block reference
btjacker
Post by btjacker » Fri Nov 23, 2018 1:36 pm
Hi, is it possible to change the order in drop down menu (see picture)? I have block with five attributes and when inserting this block reference, usually I need to change only one attribute, so I would like to have that one preselected in drop down menu. I have not figured out how they are sorted. Thank you
2018-11-23 12_30_34-vne.dxf _ - QCAD.png (11.02 KiB) Viewed 5141 times
Re: Order of attributes in drop down menu when inserting block reference
Post by andrew » Fri Nov 23, 2018 2:03 pm
I can confirm that their order is undefined at this point. These will be sorted alphanumerically in the next release.
btjacker
Post by btjacker » Thu Nov 29, 2018 10:10 am
OK, thanks for the reply. It would be better for me, if I could have influence on the order of attributes. For example choose in configuration, If I want to sort them alphanumerically, or according to Draw Order or something else I can modify to affect order. The reason is in my first post:
But anyway, the alphanumeric order is much moore better than random :wink:
Post by andrew » Thu Nov 29, 2018 3:58 pm
You could name that one attribute for example "_myattribute" to make it appear at the top.
Papy Octet
Post by Papy Octet » Sun Dec 02, 2018 10:36 am
Maybe inserting a number at the beginning of the names of the attributes. :wink:
Debian 10 - Qcad-Prof 3.19.0.0
