When Printing from PDF, and on the exported PDF, lines & Dimension text is too light (CANNOT SEE), yet in the drawing the same can be seen.
How do I fix?
Drawing & PDF, and screen shot close up of example can barely see dimension text & lines, (3)files attached, see below.
additionally added 2 more screen shot s one showing PDF after I changed scale factor from 1 to 3 in drawing preferences, text is larger yet still light can barely be seen. 2nd screenshot provided shows its dark in preview paper space( yet not in PDF) to be able to print at printer I need to print from a PDF, unless there's a way to print form the DWG/dfx (so far printer's say no they dont do it that way)
QCAD Professional
Version:
3.21.3.0 (3.21.3)
Internet:
QCAD.org
Build Date:
Sep 17 2018
Revision:
4b91c8c
Qt Version:
5.5.1
Architecture:
x86_64
Compiler:
MSVC++ 12.0 (2013)
Windows 7
Printing & PDF lines & Dimension text CANNOT SEE, yet drawing can see
- DWG V10z3 1 bed prop demo.dwg
- (172.07 KiB) Downloaded 328 times
- Screen shot shows cannot see dimension text example above min side setback.JPG (58.55 KiB) Viewed 2664 times
- A-1 Boone RD.pdf
- (295.8 KiB) Downloaded 329 times
Re: Printing & PDF lines & Dimension text CANNOT SEE, yet drawing can see
1. Show the layer list View > Layer List
2. Click on layer Dimensioning
3. Menu: Layer > Edit Layer
4. Change Lineweight to 0.13mm (or any other desired value)
Note that printers have a much higher resolution than screens and the thinnest line on screen is 1px while the thinnest line on a printer might not be visible at all.
