Text strings from AutoCAD don't always wrap correctly
Posted: Fri Jan 04, 2019 12:05 am
I have an AutoCAD DWG file from an outside source.
Some of the text strings which should be wrapped within a text box do not get wrapped in QCAD 3.21.3
For example see the string "These reaction forces ..." in the rightmost lower panel.
When I use a DWG to PDF conversion tool, the text does get properly wrapped in the box, as intended in AutoCAD, but this does not happen in QCAD. Instead a single long text string appears, and this also appears in the PDF produced by QCAD.
I have attached the DWG file. I have not attached the two PDF files, as they are fairly large, but I can send them if that helps.
Is there a way to make QCAD handle this sort of thing consistent with other DXF or DWG software?
Thanks,
- charles
Thanks,
- charles
