ver.3.21.3pro. unable to exit QCAD
I am unable to close the program. the minimised / maximised/close box ( top right hand corner are not visible ) also i do not see the Mouse which I understand should be at the bottom of the page just below the Command Line help advise required please.
Re: ver.3.21.3pro. unable to exit QCAD
What is your Operation System?
Thanks for your interest in my problem. I'm new to all of this (Forum) I 'm using a Win 10 pro. i3 16GB mem. GF 730card.
One possibility could be that QCAD is in a Full screen mode. Try to toggle back witch the F11 key on your keyboard or use the Menu
From across the pond, A Very Big Thank you problem solved.
You're welcome.
