layers, Error: Please check for block recursions
rich999
Post by rich999 » Mon Feb 04, 2019 8:05 pm
Ubuntu 18.04, Qcad 3.21.3.0 (3.21.3)
I am drawing a home outline on a lot. I have two versions of placement.
Can I draw one version on a layer, then turn off that layer and draw the other version on another layer ? The two versions do overlay each other, but when I print I would turn off one or the other layer.
Is there some reason I can't overlay on different layers ?
I get an error:
Transaction failed. Please check for block recursions and locked or invisible layers or blocks.
Re: layers, Error: Please check for block recursions
Post by Husky » Mon Feb 04, 2019 8:22 pm
Yes, that will work.
I get an error:
Quite likely the active layer is locked. Check the Layer list for the red padlock. If that doesn't solves the issue please attach the drawing. Thanks.
rich999
Post by rich999 » Mon Feb 04, 2019 10:16 pm
Thank you, it was something to do with layers. Its working.
Still learning.
