How can I divide a rectangle unevenly
Posted: Sat Mar 30, 2019 6:03 pm
I'm new to QCAD Pro and my general CAD knowledge is limited...
I want to fill simple 2D drawings for a top and side view of a bowl with segments and slices, adding to the side view, unequal dividers using a script (or otherwise).
I have a drawing of a segmented bowl that has a 2D top view that appears as a circle that's divided into 8 segments and a side view that has 5 slices.
I would like to add dividers which are not equally spaced. e.g. with 8 segments only 3 additional unequal dividers are required to show the side view.
Perhaps there is already a way to map the top view to the side view e.g. to project lines which help identify intersection points to define where the divisions should be placed?
