QCAD Pro 3.21.3.15 on Ubuntu 16.04
Is it possible to draw a curve based on mathematical equations?
As a simple example, I need to draw a family of hyperbolas with the same asymptotes. Similarly, I need to draw some ellipses.
The equations can be given in parametric form for x and y coordinates, for example.
Is it possible to do this in qcad?
Thanks, and cheers,
- charles
drawing curve based on mathematical equation
Re: drawing curve based on mathematical equation
Yes, using the script interface. Please have a look at this example:
https://qcad.org/en/tutorial-running-sc ... rom-a-file
Thanks for the help and suggestion.
In some cases it would be useful to be able to pass arguments to such a function in some way. I am new to this area, and I have not yet come across the way to do this. Where is the best place to look further for such functionality.
While the capability of writing such functions in C is very good, given the rapid expansion of Python into so many areas, is there any plan to add Python as a language in which one can write such functions?
Thanks very much for you help with this.
Cheers,
- charles
Cheers,
- charles
As soon as you want the user to be able to input something (enter values, click coordinates, etc.) you're looking at an interactive script:
https://qcad.org/en/tutorial-interactive-script-actions
This is all ECMAScript (JavaScript) by the way, not C.
No plans for Python (or Ruby, Haskell, LISP, etc.)
