Where is the source code of offset function?
hys1994
Post by hys1994 » Thu Apr 18, 2019 4:47 pm
Dear all,
I'm looking for the source code of offset function. I want to do some research about it.
Thank you for your help. Best regards,
YuSheng
Re: Where is the source code of offset function?
Post by andrew » Tue Apr 23, 2019 3:38 pm
If you are referring to the polyline offset tool, this is part of QCAD Professional and not open source. See also https://www.qcad.org/en/documentation/features
