Start Qcad without opening a new drawing
ssobol
Post by ssobol » Sat Apr 27, 2019 6:57 pm
Everytime Qcad starts it opens a new blank drawing. How do I turn this off?
I can't find anything in the application preferences that controls this.
Thanks.
Re: Start Qcad without opening a new drawing
Post by Husky » Sat Apr 27, 2019 7:28 pm
That's a default setting which can't be turned off.
TSG
Post by TSG » Sun Apr 28, 2019 8:46 am
Of course you can change it.
Under "Edit / Application Preferences / File / Templates" you can define any drawing as "Default Template".
Under "Template Folder" you can define where QCAD will look for this "Default Template".
My Default Template is called "Standardvorlage.dxf" (its in german but the name doesn't matter as long as it's the same name you defined in the Application Preferences (see above). My "Standardvorlage.dxf" contains my standard layers, my drawing units, my drawing head, some paper spaces and so on.
Hope it helps
Thomas
ssobol
Post by ssobol » Tue May 28, 2019 11:23 pm
I realize I can change the starting template. However, I am much more likely to be opening a previous drawing to continue to work on it than start a new one.
Having QCad open a new drawing every time I start it is unnecessary.
TSG
Post by TSG » Tue Jun 04, 2019 8:14 am
If you want QCAD to start with a specific drawing you can make in Finder or Explorer a double click on that drawing and QCAD will start and load it.
I use this file orientated workflow not only for drawings but also for every other office document.
Greets Thomas
