Setting dimention units
mlwoy
Post by mlwoy » Wed May 15, 2019 6:49 am
Operating system Windows 7
Qcad version 3.21.2.0
Built a drawing a month ago and have been modifying it for a while. Tonight I tried to dimension the drawing and the units showed up as metric. The units are set on inches however every time i draw a dimension line it shows up in millimeters. The old dimension lines show up in inches but any added now come in in metric. This is happening not only in one drawing but others as well.
When I use "Info" and "Distance to Point" the measurement comes up in inches.
How do I reset the program to dimension in inches.
I downloaded a dfx file the night before and tried to dimension it and it was in millimeters, I tried to convert the drawing to inches and could not change it what ever I did. So some way I must have messed up the setting.
Please help
Re: Setting dimention units
Post by Husky » Wed May 15, 2019 8:04 am
I'm not sure what you have done with that drawing but here a basic info:
If you have a metric drawing (lets say mm) and you convert it with the "Convert Drawing Unit" tool below Menu / Edit to imperial (lets say inch) then QCAD will recalculate everything in your drawing to the chosen new unit.
Example: If a line was drawn with a lengths of 100 mm then it is now a line with 3.937... inch.
If you use the "Drawing Preferences" below Menu / Edit to change the drawing unit then QCAD will ONLY change the name of the unit.
Example: If a line was drawn with a lengths of 100 mm then it is now a line with 100 inch.
An other possibility would be that you used a scale factor for dimensioning and forgot to change that again. Please doublecheck the dim option bar for the scale factor. I assume it needs to be 1:1. That would explain why the Info tools shows everything in inches.
