... use polyline in a for... loop in a script?
chattermark
Post by chattermark » Wed Jun 05, 2019 10:05 pm
Simple task, I thought. A script that draws a spiral with some individual parameters (as an exercise).
What would the nomenclature be like, how do I combine the for loop and the resulting single points with the other parameters (start, closed etc.)?
The for.. - loop within the polyline parameter set, or how?
I tried to find out something from the inherent spiral script, but did not find any example source for it, nor for any other usable script (except draw 0,0,100,100)- How should I proceed?
A practical example would probably help not only me.
Thanks, cheers,
Chattermark aka Ulli
Don't try to fix it if it ain't broken.
Re: ... use polyline in a for... loop in a script?
Post by andrew » Wed Jun 05, 2019 10:13 pm
First, please refer to our scripting tutorials (with examples):
https://qcad.org/en/tutorial-script-programming
If this does not answer your question, there are plenty more examples at:
https://github.com/qcad/qcad/tree/master/scripts
Start with those in https://github.com/qcad/qcad/tree/maste ... c/Examples.
For example the spiral example script at:
https://github.com/qcad/qcad/tree/maste ... MathSpiral
chattermark
Post by chattermark » Thu Jun 06, 2019 6:10 am
Thanks. Exactly the pointers to what I needed. Something for the FAQ?
Cheers,
U.
