How to change dimension units
mlwoy
Post by mlwoy » Wed Jun 26, 2019 5:01 pm
Qcad version 3.21.2
Operating System Windows 7
Created a drawing and went to dimension it. Dimension settings are as follows:
Scale Factor 1
Format: Architectural
Precision: 0'-0 1/4"
Have a line which shows it's length as 2.5" in the Properties Editor
When dimensioned horizontally lists out as 5' 7.25"
How do I change the settings to get the dimention to reflect the correct length of the line.
I would like the dimension format to reflect the length as 2.5"
Re: How to change dimension units
Post by Husky » Wed Jun 26, 2019 5:35 pm
When you launch a dimension tool an option bar will pop up. Please make sure that the scale factor is 1:1.
If that isn't the reason for your issue please attache an example drawing to the post. Thanks.
