Is the point in entity(polyline, rect, triangle)
slymn++
Post by slymn++ » Tue Jul 23, 2019 2:21 pm
Hello
I have point list and closed contour(rectangle, triangle, polyline)
I want to find out which point is in the closed contour
Is there any related function
Best Regards.
Re: Is the point in entity(polyline, rect, triangle)
Post by andrew » Tue Jul 23, 2019 3:23 pm
You can create a polyline from any of these shapes and then use:
RPolyline::contains
slymn++
Post by slymn++ » Tue Jul 23, 2019 3:39 pm
Thanks Andrew,
I tried it
