Unable to open QCAD
Gavindah
Unable to open QCAD
Post by Gavindah » Wed Aug 07, 2019 2:20 am
Hello, I just downloaded and extracted the zip file of QCAD pro for linux 64 but I am unable to open the qcad-bin executable file. Same file opens for me in the trial version but not the pro version. Do I need to delete the trial version first? or something else? :oops:
Re: Unable to open QCAD
Post by Husky » Wed Aug 07, 2019 3:42 am
Hi - welcome to the QCAD Forum,
You could keep both versions on your system but never mix versions in the same directory. Make sure the pro is installed in a new or empty subdirectory and it should work as expected. Keep us posted :wink:
Gavindah
Post by Gavindah » Wed Aug 07, 2019 4:25 am
Thanks for that! I deleted the trial version but that didn't help. Then I deleted the pro version, and downloaded the zip file again, then extracted to an empty sub-directory but I'm still unable to open! :?
Post by Husky » Wed Aug 07, 2019 5:55 am
Did you use this installation guide?
https://qcad.org/en/documentation/insta ... ux_Systems
Post by andrew » Wed Aug 07, 2019 6:58 am
The startup script is called "qcad", not "qcad-bin".
