Running the Command Line Tools Script Example
frb
Post by frb » Wed Aug 07, 2019 8:02 pm
Hi all,
I have installed the CAD 3.23.0 / Windows x86_64
I am trying to run the example from:
https://qcad.org/en/tutorial-command-line-tool-scripts
My QCAD is installed at
C:\Program Files\QCAD>
and the script which comes with the source code is at
C:\Qcad\qcad\scripts\Tools\ExTool\ExTool.js
I run the command
C:\Program Files\QCAD>qcad -autostart C:\Qcad\qcad\scripts\Tools\ExTool\ExTool.js
and nothing happens, I am expecting the file out.dxf to be created somewhere but nothing happens, what am I doing wrong?
Thanks, BR
Fernando
Re: Running the Command Line Tools Script Example
Post by andrew » Thu Aug 08, 2019 1:10 pm
Can you try:
qcad.exe -autostart scripts/Tools/ExTool/ExTool.js
frb
Post by frb » Thu Aug 08, 2019 9:04 pm
Hello Andrew,
Thanks for the answer,
I´ve done as requested and again nothing happens.
If you or somebody could record a video showing how to run the command line script, the folder structure, where the files are located and where the output file is created it would be useful.
Thanks best regards
Fernando
Post by andrew » Fri Aug 09, 2019 9:19 am
Did you also pass the parameters as indicated in the tutorial?
I.e.:
qcad.exe -autostart scripts/Tools/ExTool/ExTool.js -f -o out.dxf in.dxf
Where in.dxf is an existing DXF file in the QCAD installation directory (where the qcad.exe file is).
frb
Post by frb » Fri Aug 09, 2019 4:51 pm
Hello Andrew,
Yes I do have a in.dxf file in the same folder where qcad.exe is
I typed
C:\Program Files\QCAD>qcad.exe -autostart scripts/Tools/ExTool/ExTool.js -f -o out.dxf in.dxf
and all I have is
Sometimes we can not run stuff properly from the folder Program Files due to the windows restrictions, then I reinstalled everything in
C:\QCADCAM>
and I run both commands below
C:\QCADCAM>qcad.exe -autostart scripts/Tools/ExTool/ExTool.js -f -o out.dxf in.dxf
C:\QCADCAM>
C:\QCADCAM>qcad.exe -autostart C:\Qcad\qcad\scripts\Tools\ExTool\ExTool.js -f -o out.dxf in.dxf
C:\QCADCAM>
The last because my qcad source code is in a different folder
the out.dxf was not created anywhere, I do not have any message printed in my console
thanks, regards
Fernando
Post by andrew » Wed Aug 14, 2019 9:25 am
You might want to try:
qcad.exe -autostart scripts/Tools/ExTool/ExTool.js -f -o out.dxf in.dxf 2>log
And then:
type log
To see if there are any errors.
