Cant repport bug...
SerPat
Cant repport bug...
Post by SerPat » Mon Aug 19, 2019 3:41 am
I did not understand how to repport a bug, so I post here and will not go further (dont want to).
Version: 3.23.0.0 (3.23.0)
Internet: QCAD.org
Build Date: Jul 18 2019
Revision: 42e52bf
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
The angle dimension function crashed without a call (forced to kill QCad, at least on the first crash). I attach a file where the bug can be reproducible: just move the cursor around the junction bridge of the two lines.
This picture is a X snapshot while QCad is freezed.
Bug.dxf
(109.55 KiB) Downloaded 164 times
I hop that a moderator will remove that post once "handled".
Re: Cant repport bug...
Post by Husky » Mon Aug 19, 2019 4:50 am
I tried to reproduce that behavior. No luck - works fine for me. Looks like the angle dim was rotated, correct? What else was modified? Just "move the cursor around the junction" didn't the trick ...
J-J
Moderator
Post by J-J » Fri Aug 23, 2019 8:20 pm
Seems to work fine here too...?
JJ Win7 pro-64
