roozgar
Post
by roozgar » Sat Aug 31, 2019 7:26 pm
hello
i installed trial version to check the system but i cant to run the command line tool to convert dwgtopdf
in on ubuntu 18
and used the last version of qcad
this is my output
peiman@server:~/opt/qcadcam-3.23.0-trial-linux-x86_32$ ./dwg2pdf a.dwg a.pdf
./qcad: line 9: ./qcad-bin: No such file or directory
QCAD has unexpectedly quit.
Please use the offscreen platform plugin for headless systems
(without a running X11 server):
./qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
./qcad -style plastique
how can i run the headless version !?
Post
by andrew » Mon Sep 02, 2019 8:23 am
Please post the output of the following commands (in directory ~/opt/qcadcam-3.23.0-trial-linux-x86_32):
roozgar
Post
by roozgar » Mon Sep 02, 2019 8:50 am
thank you for your answer
peiman@server:~/opt/qcadcam-3.23.0-trial-linux-x86_32$ ls -la
total 150024
drwxrwxr-x 16 peiman peiman 4096 Sep 1 00:58 .
drwxrwxr-x 3 peiman peiman 4096 Aug 31 22:23 ..
-rwxrwxr-x 1 peiman peiman 260531 Aug 31 22:23 adinit.dat
-rw-r--r-- 1 root root 1000 Aug 31 22:33 a.dwg
-rwxrwxr-x 1 peiman peiman 179 Aug 31 22:23 bbox
-rw-r--r-- 1 root root 539424 Mar 31 2016 Bearing_www.tutoautocad.com.dwg
-rw-rw-r-- 1 peiman peiman 19466 Aug 31 22:23 cc-by-3.0.txt
-rw-r--r-- 1 root root 16731 Mar 31 2016 Chaise_art_1_www.tutoautocad.com.dwg
-rw-r--r-- 1 root root 16731 Mar 31 2016 Chaise_art_1_www.tutoautocad.com.dwg.1
-rwxrwxr-x 1 peiman peiman 173 Aug 31 22:23 dwg2bmp
-rwxrwxr-x 1 peiman peiman 173 Aug 31 22:23 dwg2dwg
-rwxrwxr-x 1 peiman peiman 183 Aug 31 22:23 dwg2maptiles
-rwxrwxr-x 1 peiman peiman 173 Aug 31 22:23 dwg2pdf
-rwxrwxr-x 1 peiman peiman 173 Aug 31 22:23 dwg2svg
-rwxrwxr-x 1 peiman peiman 175 Aug 31 22:23 dwghatch
-rwxrwxr-x 1 peiman peiman 173 Aug 31 22:23 dwginfo
drwxrwxr-x 3 peiman peiman 4096 Aug 31 22:23 examples
drwxrwxr-x 3 peiman peiman 4096 Aug 31 22:23 fonts
-rw-rw-r-- 1 peiman peiman 933 Aug 31 22:23 gpl-3.0-exceptions.txt
-rw-rw-r-- 1 peiman peiman 35147 Aug 31 22:23 gpl-3.0.txt
-rw-rw-r-- 1 peiman peiman 7652 Aug 31 22:23 lgpl.txt
-rwxr-xr-x 1 peiman peiman 25336904 Aug 31 22:23 libicudata.so.54
-rwxr-xr-x 1 peiman peiman 3152461 Aug 31 22:23 libicui18n.so.54
-rwxr-xr-x 1 peiman peiman 1949914 Aug 31 22:23 libicuuc.so.54
-rwxrwxr-x 1 peiman peiman 6840437 Aug 31 22:23 libqcadcore.so
-rwxrwxr-x 1 peiman peiman 25234983 Aug 31 22:23 libqcadecmaapi.so
-rwxrwxr-x 1 peiman peiman 1341167 Aug 31 22:23 libqcadentity.so
-rwxrwxr-x 1 peiman peiman 49850 Aug 31 22:23 libqcadgrid.so
-rwxrwxr-x 1 peiman peiman 704183 Aug 31 22:23 libqcadgui.so
-rwxrwxr-x 1 peiman peiman 182253 Aug 31 22:23 libqcadoperations.so
-rwxrwxr-x 1 peiman peiman 91623 Aug 31 22:23 libqcadsnap.so
-rwxrwxr-x 1 peiman peiman 64227 Aug 31 22:23 libqcadspatialindex.so
-rwxrwxr-x 1 peiman peiman 197820 Aug 31 22:23 libqcadstemmer.so
-rwxr-xr-x 1 peiman peiman 959680 Aug 31 22:23 libQt5CLucene.so.5
-rwxr-xr-x 1 peiman peiman 20896 Aug 31 22:23 libQt5Concurrent.so.5
-rwxr-xr-x 1 peiman peiman 5527300 Aug 31 22:23 libQt5Core.so.5
-rwxr-xr-x 1 peiman peiman 600592 Aug 31 22:23 libQt5DBus.so.5
-rwxr-xr-x 1 peiman peiman 7011644 Aug 31 22:23 libQt5Gui.so.5
-rwxr-xr-x 1 peiman peiman 547704 Aug 31 22:23 libQt5Help.so.5
-rwxr-xr-x 1 peiman peiman 115300 Aug 31 22:23 libQt5MultimediaQuick_p.so.5
-rwxr-xr-x 1 peiman peiman 900480 Aug 31 22:23 libQt5Multimedia.so.5
-rwxr-xr-x 1 peiman peiman 115924 Aug 31 22:23 libQt5MultimediaWidgets.so.5
-rwxr-xr-x 1 peiman peiman 1638928 Aug 31 22:23 libQt5Network.so.5
-rwxr-xr-x 1 peiman peiman 383424 Aug 31 22:23 libQt5OpenGL.so.5
-rwxr-xr-x 1 peiman peiman 282840 Aug 31 22:23 libQt5Positioning.so.5
-rwxr-xr-x 1 peiman peiman 469664 Aug 31 22:23 libQt5PrintSupport.so.5
-rwxr-xr-x 1 peiman peiman 4795220 Aug 31 22:23 libQt5Qml.so.5
-rwxr-xr-x 1 peiman peiman 605760 Aug 31 22:23 libQt5QuickParticles.so.5
-rwxr-xr-x 1 peiman peiman 4335184 Aug 31 22:23 libQt5Quick.so.5
-rwxr-xr-x 1 peiman peiman 126324 Aug 31 22:23 libQt5QuickTest.so.5
-rwxr-xr-x 1 peiman peiman 61492 Aug 31 22:23 libQt5QuickWidgets.so.5
-rwxr-xr-x 1 peiman peiman 2729832 Aug 31 22:23 libQt5Script.so.5
-rwxr-xr-x 1 peiman peiman 789248 Aug 31 22:23 libQt5ScriptTools.so.5
-rwxr-xr-x 1 peiman peiman 237740 Aug 31 22:23 libQt5Sensors.so.5
-rwxr-xr-x 1 peiman peiman 295952 Aug 31 22:23 libQt5Sql.so.5
-rwxr-xr-x 1 peiman peiman 368724 Aug 31 22:23 libQt5Svg.so.5
-rwxr-xr-x 1 peiman peiman 130136 Aug 31 22:23 libQt5WebChannel.so.5
-rwxr-xr-x 1 peiman peiman 39659908 Aug 31 22:23 libQt5WebKit.so.5
-rwxr-xr-x 1 peiman peiman 297948 Aug 31 22:23 libQt5WebKitWidgets.so.5
-rwxr-xr-x 1 peiman peiman 175976 Aug 31 22:23 libQt5WebSockets.so.5
-rwxr-xr-x 1 peiman peiman 7576944 Aug 31 22:23 libQt5Widgets.so.5
-rwxr-xr-x 1 peiman peiman 10872 Aug 31 22:23 libQt5X11Extras.so.5
-rwxr-xr-x 1 peiman peiman 1562608 Aug 31 22:23 libQt5XcbQpa.so.5
-rwxr-xr-x 1 peiman peiman 3892460 Aug 31 22:23 libQt5XmlPatterns.so.5
-rwxr-xr-x 1 peiman peiman 275228 Aug 31 22:23 libQt5Xml.so.5
-rwxrwxr-x 1 peiman peiman 110870 Aug 31 22:23 libqtcsg.so
drwxrwxr-x 4 peiman peiman 4096 Aug 31 22:23 libraries
-rwxrwxr-x 1 peiman peiman 574025 Aug 31 22:23 libspatialindexnavel.so
-rw-rw-r-- 1 peiman peiman 1736 Aug 31 22:23 LICENSE.txt
drwxrwxr-x 4 peiman peiman 4096 Aug 31 22:23 linetypes
-rwxrwxr-x 1 peiman peiman 167 Aug 31 22:23 merge
-rw-rw-r-- 1 peiman peiman 13813 Aug 31 22:23 mimetype.png
drwxrwxr-x 4 peiman peiman 4096 Aug 31 22:23 patterns
drwxrwxr-x 2 peiman peiman 4096 Aug 31 22:23 platforminputcontexts
drwxrwxr-x 2 peiman peiman 4096 Aug 31 22:23 platforms
drwxrwxr-x 7 peiman peiman 4096 Aug 31 22:23 plugins
drwxrwxr-x 2 peiman peiman 4096 Aug 31 22:23 postprocessors
-rwxrwxr-x 1 peiman peiman 572 Aug 31 22:23 qcad
-rwxrwxr-x 1 peiman peiman 30644 Aug 31 22:23 qcad-bin
-rw-r--r-- 1 root root 1024 Aug 31 22:46 .qcad-bin.swp
-rw-rw-r-- 1 peiman peiman 66426 Aug 31 22:23 qcad_icon.png
-rw-rw-r-- 1 peiman peiman 776 Aug 31 22:23 qcad-mimetypes.xml
-rwxrwxr-x 1 peiman peiman 580 Sep 1 00:58 qcad.save
-rw-r--r-- 1 root root 1024 Aug 31 22:46 .qcad.swp
-rw-rw-r-- 1 peiman peiman 396 Aug 31 22:23 readme.txt
-rw-rw-r-- 1 peiman peiman 41 Aug 31 22:23 revision.txt
-rwxrwxr-x 1 peiman peiman 2694 Aug 31 22:23 Ribbonsoft-qcad.desktop
drwxrwxr-x 4 peiman peiman 4096 Aug 31 22:23 scripts
-rwxrwxr-x 1 peiman peiman 173 Aug 31 22:23 svg2dwg
drwxrwxr-x 3 peiman peiman 4096 Aug 31 22:23 themes
drwxrwxr-x 2 peiman peiman 12288 Aug 31 22:23 ts
-rwxrwxr-x 1 peiman peiman 2681 Aug 31 22:23 uninstall
drwxrwxr-x 2 peiman peiman 4096 Aug 31 22:23 xcbglintegrations
drwxrwxr-x 2 peiman peiman 4096 Aug 31 22:23 xdg
also your second command output
peiman@server:~/opt/qcadcam-3.23.0-trial-linux-x86_32$ uname -m
x86_64
warm regards
Post
by andrew » Mon Sep 02, 2019 9:04 am
x86_64
You are using a 64bit Linux system. Please download and install the 64bit package of QCAD or QCAD/CAM.
roozgar
Post
by roozgar » Mon Sep 02, 2019 11:56 am
thank you
its working
the 15 second delay is for trial version?!
roozgar on Mon Sep 02, 2019 12:06 pm, edited 2 times in total.
Post
by andrew » Mon Sep 02, 2019 11:58 am
roozgar wrote: ↑Mon Sep 02, 2019 11:56 am
Yes.
roozgar
Post
by roozgar » Mon Sep 02, 2019 12:07 pm
ok good, i will buy the license to avoid this limit
but
the output is a blank white pdf page with 25 mb size
how can this possible or i do something wrong!??!?
the file is attached here
- m.dwg
- (3.86 MiB) Downloaded 308 times
Post
by andrew » Mon Sep 02, 2019 1:37 pm
Seems to work fine here.. What's your command line?
I've used:
./dwg2pdf -a -l -p A4 -f -o m.pdf m.dwg
roozgar
Post
by roozgar » Mon Sep 02, 2019 1:53 pm
this is my output of ssh
peiman@server:~/opt/qcad-3.23.0-trial-linux-x86_64$ sudo ./dwg2pdf -platform offscreen -a -l -p A4 -f -o m.pdf m.dwg
[sudo] password for peiman:
QCAD version 3.23.0
17:14:36: Debug:
You are using a trial version of QCAD Professional.
17:14:36: Debug: If you would like to use this software productively,
17:14:36: Debug: please purchase the full version for a small license fee from our
17:14:36: Debug: Online Shop at:
17:14:36: Debug: http://www.ribbonsoft.com/shop
17:14:36: Debug: Thank you for trying this add-on!
17:14:36: Debug: Your script will start in 15 seconds...
17:14:51: Debug: calling odInitialize
Converting
from: /home/peiman/opt/qcad-3.23.0-trial-linux-x86_64/m.dwg
to : /home/peiman/opt/qcad-3.23.0-trial-linux-x86_64/m.pdf
17:15:18: Debug: bb: RBox(4.52197,4.29428: 15.1459x6.31028)
17:15:18: Debug: f: 19.609328555722954
but the output is a blank white pdf file.it seems there is a problem in file because some other file working good.
Post
by andrew » Tue Sep 03, 2019 7:57 am
Can you upload the PDF file somewhere? It could be that the PDF file is fine but your viewer refuses to display it (or is very slow to display it).
