Create auxiliary lines
Bespoke
Post by Bespoke » Fri Sep 13, 2019 6:13 am
How do I create auxiliary lines?
WINDOWS 10
Version:
3.23.0.0 (3.23.0)
Internet:
QCAD.org
Build Date:
Jul 18 2019
Revision:
42e52bf
Qt Version:
5.5.1
Architecture:
x86_64
Compiler:
MSVC++ 12.0 (2013)
Re: Create auxiliary lines
Post by andrew » Fri Sep 13, 2019 7:41 am
Every line tool in QCAD offers the option to create a construction line (X-Line, Infinite line) instead of a line segment:
https://qcad.org/doc/qcad/latest/refere ... e/doc/Line
Simply choose the desired line type in the options toolbar at the top when creating a line.
Auxiliary lines / constructions are typically created on a separate layer, for example one called "auxiliary".
P.S.: Please avoid ALL CAPITALS in forum titles and posts, thanks. I've adjusted your title.
Bespoke
Post by Bespoke » Fri Sep 13, 2019 10:00 am
Thank you for the response
I cannot locate the options that is mentioned in the link. I have searched the qcad book and no mention is made of these line options.
See attachment
Create auxiliary linesI.docx
(68.7 KiB) Downloaded 264 times
Post by andrew » Fri Sep 13, 2019 10:16 am
Almost there. Click one of the line tool (whichever is appropriate), then you'll see the options toolbar:
Screenshot 2019-09-13 at 11.15.32.png (40.16 KiB) Viewed 3832 times
Bespoke
Post by Bespoke » Fri Sep 13, 2019 10:43 am
Thank you Andrew, I can see it!
Now I need to understand how it works...A bit different to what I have been used to in an application I used quite a while ago. (Caddie)
Post by andrew » Fri Sep 13, 2019 1:29 pm
The important thing to realise is that construction lines are just ordinary entities in QCAD. The only thing that makes them construction lines is the fact that you know they are intended as construction lines. To visualise that, place them on a separate layer and give that layer a colour that is distinguishable from the rest of the drawing. You can also place arcs, circles, etc. on that layer. Everything that is intended as auxiliary construction.
