URGENT: to separate layers in Dwg / dxf
pocorrea
Post by pocorrea » Tue Oct 01, 2019 8:29 pm
Hi, I received a DXF but I need to separate layers to work in another application.
I need to modify the arq2.DXF file to be separated and colored layers like the arq1.dxf file
Could someone help me do this in QGIS?
Thanks a lot.
Re: URGENT: to separate layers in Dwg / dxf
Post by Husky » Tue Oct 01, 2019 9:03 pm
It's hard for me to believe they used only two layer for arq2.dxf. How did you load it into QCAD Trial? Menu File / Open or import? If you imported the file try instead just to open it
Probably not - this is the QCAD Forum.
Post by CVH » Wed Oct 02, 2019 6:23 am
Depends if Z is used.
If so, you could re-seperate by altitude in Z.
Without a file we can't even know that.
Your welcome to post both files.
QCADpro 3.25.2.1 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
