flange.dxf disappeared
uflem
Post by uflem » Thu Oct 03, 2019 10:44 pm
I installed an update on my MacBook Pro OS 10.14.5 and since then, I cannot find flange.dxf anywhere (I want to study it to learn about layouts); i.e. Find flange.dxf returns nothing. Is there a way to download it from somewhere?
Re: flange.dxf disappeared
Post by Husky » Thu Oct 03, 2019 11:44 pm
Hopefully nothing else is missing ... :D :D :D
flange.dxf
(297.58 KiB) Downloaded 169 times
Normally it should be below ... QCAD directory/examples
Post by andrew » Fri Oct 04, 2019 7:57 am
Under macOS, the example files are in the DMG under "examples".
uflem
Post by uflem » Fri Oct 04, 2019 10:06 pm
This folder does not exist on my Mac
Post by Husky » Fri Oct 04, 2019 10:16 pm
Note: Only a proper QCAD installation ensures a stable running program. Please doublecheck with this installation instruction for a macOS installation:
https://qcad.org/en/documentation/insta ... nder_macOS
uflem
Post by uflem » Sat Oct 05, 2019 2:34 am
I did all of this--I do not know how else QCAD would be running on my Mac anyway.
