flange.dxf
Gerardf
flange.dxf
Post by Gerardf » Thu Oct 10, 2019 11:11 pm
Hi All,
I note this very nice dwg is much better than my isometric attempts.
My isometric drawings are really a wire-frame presentation quite unlike the isometric view in flange.dxf.
Can someone advise further steps to moving from the wire-frame kind of thing to something more realistic?
Re: flange.dxf
Post by Husky » Fri Oct 11, 2019 3:16 am
That is manually done - entity by entity. Everything what is normally invisible (behind something else) needs to go away. You can use for that task a bunch of QCAD tools like "Break out", "Divide", "Trim", "Delete" etc.
Yes, it is a Sisyphus task but the good thing is you will learn a lot about those "Modify" tools. :wink:
