Is it possible to convert lines to closed polyline?
HappyShat
Post by HappyShat » Fri Oct 11, 2019 8:27 pm
I've got a shape that I'm importing into another CAD program. I'd like to change the attached drawing to be a closed polyline. Is this possible? I noticed that I have the extension DXF for the file name. Should I save as a DWG file first?
Thanks for your help!
My System and QCAD version:
Windows 10 Prof.
QCAD version 3.22.1.0
import_region_test.dxf
(104.01 KiB) Downloaded 16 times
Re: Is it possible to convert lines to closed polyline?
Post by Husky » Fri Oct 11, 2019 8:47 pm
Yes, that is possible with the "Polyline from Segments" tool. (Menu, Draw, Polyline). It will work at dxf and dwg. :wink:
Doublecheck the "closed" status within the Property Editor.
