Selection priorities
Krischu
Senior Member
Post by Krischu » Tue Oct 22, 2019 3:03 pm
Just a question: when you have a circle with a polygonal cross hair in it and you hover over the midpoint, it seems that the center is covered by the interection. So alway intersection is offered as the snap point.
Is there a way (keyboard shortcut or modifier) that changes the intersection to the center (they may be equivalent though)?
Christoph
Re: Selection priorities
Post by CVH » Tue Oct 22, 2019 5:45 pm
At the left you will see the snap options when referencing.
You can also open the Snap menu item.
Snapping is usually Auto with no restrictions.
Lots of choises there.
In App.Prefs Snap you can enable or disable the auto state of individual methods.
You can't alter the hierarchy if references may coincide.
QCADpro 3.23.0.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
