block update and name
jim78b
Post by jim78b » Thu Oct 24, 2019 7:36 am
Win7 64, qcad last release
Hello
if I already have a block and I want to add elements from the outside, I have to explode the block and recreate it, isn't there a faster system?
If you select the block how can I know your name?
isn't there a way like autocad to edit the blocks in place, seeing what's around us?
Re: block update and name
Post by andrew » Thu Oct 24, 2019 8:39 am
For example: copy the entities, edit the block, paste the entities.
In the property editor (View > Property Editor).
No.
jim78b
Post by jim78b » Mon Oct 28, 2019 10:38 am
thanks for reply, for the block name i select the block in drawing but qcad don't show me the name of select block, i think must i search it in the property editor list right?
is bad thing that can not edit block like autocad :(
