Can I merge blocks?
matt____jackson
Can I merge blocks?
Post by matt____jackson » Wed Nov 20, 2019 10:21 am
I've downloaded a drawing that I need to use, it's fairly complex and has about 100 blocks. Is it possible to merge all these into 1 that I can then insert into my own drawing?
QCAD-Pro v3.22.1 on MacOS.
Re: Can I merge blocks?
Post by andrew » Wed Nov 20, 2019 10:35 am
If you copy / paste the block references into your drawing, the block definitions are also copied.
If you want to get rid of the block structure, select the block references and use Modify > Explode to explode the block references into loose entities.
If this does not answer your question, please be more specific in what you want to achieve.
matt____jackson
Post by matt____jackson » Wed Nov 20, 2019 10:51 am
Ah OK, I think that's done what I was trying to achieve thank you. I've followed that, and then when I save it and insert it into my own drawing it just adds in 1 block.
Are there any side effects to this I should be aware of when doing it? Or does it literally just remove all the block references and put the items back onto Model_Space?
Post by Husky » Thu Nov 21, 2019 6:18 am
Something doesn't add up here .... e_surprised
With "insert" you mean "Import". Correct? In that case there is no need to copy/paste or explode anything ....
