Scaling an object via the mouse
Ashley1105
Post by Ashley1105 » Thu Nov 21, 2019 5:41 am
Is there a way to select and scale an object via a mouse + keyboard command, or something similar?
So you can see the object get bigger and smaller in real time instead of guessing what increment it needs to be resized to.
I am using QCAD on iMac 10.15.1
Version of QCAD is QCAD Pro 3.23.0
Thank you.
Re: Scaling an object via the mouse
Post by Husky » Thu Nov 21, 2019 6:02 am
Yes, within the Scale dialog is the possibility given to define the scale factor with the mouse.
