Match properties
sudo_ki
Match properties
Post by sudo_ki » Fri Nov 29, 2019 12:29 pm
https://qcad.org/rsforum/viewtopic.php? ... ties#p1316
Does this function exist in the current version?
i haven't found it in the user reference manual... maybe i've overlooked something
otherwise, i suppose some scripting will help
Re: Match properties
Post by CVH » Fri Nov 29, 2019 12:51 pm
Hi
Something as Paste Format is recently added.
It's is called Property Painter Tool
https://qcad.org/rsforum/viewtopic.php?t=6520
Updated User manual at:
https://qcad.org/doc/qcad/latest/refere ... rtyPainter
sudo_ki
Post by sudo_ki » Fri Nov 29, 2019 1:30 pm
thank you, this is exactly what i was looking for
