Rotating Dimension Text
klach
Post by klach » Fri Jan 24, 2020 10:20 pm
Is there a way to change the Dimension Vertical text to be rotated 90 degrees and be perpendicular to the dimension to keep all of the vertical and horizontal dimensions the same orientation?
Re: Rotating Dimension Text
Post by CVH » Fri Jan 24, 2020 11:36 pm
I don't think so...
for the record: DL, DH & BV are all 3 of the kind 'Rotated Dims'.
That angle is the rotation angle.
You might enter a feature request...
klach
Post by klach » Thu Jan 30, 2020 10:00 pm
Hi CVH,
How does one put in for a feature request?
Post by CVH » Thu Jan 30, 2020 10:33 pm
Here:
First you have to start a new login.
It is separate from the forum or the site login.
