[SOLVED] Dimensioning
FBMeca
Post by FBMeca » Mon Apr 06, 2020 11:58 am
Please excuse me if my question is redundant. Also, QCAD is a really great program, thanks !
I've got a small problem about the values when I dimension my object. It is very small, and I haven't found any way to change the size of the text of these values. I think it is due to the fact that I've got a scale of 1:1, but I thought it didn't matter if I could just the size manually.
Could someone help me?
Thanks a lot in advance, and stay safe :)
Re: Dimensioning
Post by andrew » Mon Apr 06, 2020 12:01 pm
It's under:
Edit > Drawing Preferences > Dimensions > Dimension Settings:
Screenshot 2020-04-06 at 13.00.20.png (204.82 KiB) Viewed 5342 times
Re: Dimensioning
Post by CVH » Mon Apr 06, 2020 12:45 pm
^^^^Above ^^^^
Is for the current drawing. :wink:
Menu..Edit..Drawing Preferences (Ctrl+I)
The same can be set for all new drawings. :wink:
Menu..Edit..Application Preferences (Ctrl+,)
The red text in the header is self explanatory.
FBMeca
Re: Dimensioning
Post by FBMeca » Mon Apr 06, 2020 3:37 pm
Thanks a lot for your help, I had tried that out, but now it works !
Just another question : is it possible to choose the size of the dimensions for each dimension one by one ? Or would I have to change the preferences each time I put a dimension ?
If it's not possible, it's understandable, because it's not really common to change the size on one single drawing...
Re: Dimensioning
Post by CVH » Mon Apr 06, 2020 3:58 pm
See same story: Sat Mar 28, 2020 5:13 pm
https://qcad.org/rsforum/viewtopic.php? ... 104#p27354
In this topic all the questions about dimensions are answered.
You could try to search the forum on 'dimension' . :wink:
FBMeca
Re: Dimensioning
Post by FBMeca » Mon Apr 06, 2020 4:25 pm
Thanks a lot for your help, it's all clear now.
Another small question I just encountered : are there some tools to put some colors or for example darken some figures on my drawing ? For example if i draw a circle, and I want to put the whole circle (also the inside) in black (or some other color) ?
Sorry if I'm asking without managing to find the answer, if there is a topic that answers this i'll just look at it :)
Cheers!
Re: Dimensioning
Post by CVH » Mon Apr 06, 2020 4:53 pm
That would be yet another question in this topic.
Pls read the forum rules at the top.
Look for hatch, hatching, solid fill (also a hatch).
Best done on a seperate layer, they tend to get in the way of selections.
In combination with custom colors.
CVH.
FBMeca
Re: Dimensioning
Post by FBMeca » Mon Apr 06, 2020 6:16 pm
Thanks for your help. I tried hatching, and saw the "hatch pattern", which looked very good.
Only problem is that I don't understand how it actually works ? For the complete filling I just clicked on the circle beforehand, and it worked, but with the "hatch pattern" it didn't work.
How am I supposed to do it ?
Sorry for not creating a new thread, I think it isn't worth it. Correct me if I'm wrong :)
Re: Dimensioning
Post by CVH » Mon Apr 06, 2020 7:14 pm
It aren't my rules!
Look up: topics with boundary. :wink:
FBMeca
Re: Dimensioning
Post by FBMeca » Tue Apr 07, 2020 10:29 am
Everything works fine now, thanks a lot :D
Have a great week!
