[solved] Application properties
ryancousins
Post by ryancousins » Tue Apr 21, 2020 9:58 pm
Is there a xml file or something similar that application preferences are saved to so that if I install QCAD on a 2nd machine I don't have to set up all my preferences and menu bars, etc?
RandallG
Re: Application properties
Post by RandallG » Tue Apr 21, 2020 10:09 pm
This link shows how to not only reset the config files but also where they are located for the ini and conf files:
ryancousins
Post by ryancousins » Tue Apr 21, 2020 10:19 pm
Excellent thank you.
RandallG
Post by RandallG » Tue Apr 21, 2020 10:32 pm
No problem. Could you change the subject to [solved] on the original subject line instead of on your reply?
Thanks.
Post by Husky » Tue Apr 21, 2020 10:55 pm
Thanks.
I used my "power" to fix the issue ... :lol: :lol: :lol:
