How do I draw a double headed arrow?
maddie111
Post by maddie111 » Thu Apr 30, 2020 2:43 pm
I would like to draw a line with arrow heads at each end. I need it have a label next to it stating the minimum height of the structure I am drawing. My drawing is not to scale so the standard dimension arrow doesn't seem to be appropriate
Re: How do I draw a double headed arrow?
Post by andrew » Thu Apr 30, 2020 3:43 pm
You can enter any label for a dimension. Simply use the override edit box in the options tool bar to specify the label while drawing the dimension:
Screenshot 2020-04-30 at 16.41.05.png (128.77 KiB) Viewed 415 times
Or use the property editor later to change the label of an existing dimension entity:
Screenshot 2020-04-30 at 16.42.38.png (82.99 KiB) Viewed 415 times
maddie111
Post by maddie111 » Thu Apr 30, 2020 5:07 pm
Thank you!
