[solved] Line scale (dashed line) and printing
RaNoPlus
Post by RaNoPlus » Fri May 15, 2020 7:34 pm
Hi, Ia have a question about line scale and printing. I want to see a dashed line on the same way in model space and also in paper space. For example. When I want to see a dashed line in paper space (1:100) a have make the line in model space without scale so it's a normal continuos line. In Atuocad there is psltscale command to see the lines on the same wat as in model space. Is there anything like this command in Qcad? See attached pdf to get an idea what I mean. Thank you for your help. Regards Radek.
pict.pdf
(343.79 KiB) Downloaded 37 times
Re: Line scale (dashed line) and printing
Post by Husky » Fri May 15, 2020 8:16 pm
Make sure that "Screen-based Linetypes" is active
If that doesn't solves the issue please attache the dxf/dwg. Thanks.
RaNoPlus
Post by RaNoPlus » Fri May 15, 2020 8:48 pm
Great. This works perfectly! Thanks. I am really enthusiastic about this software. It's like my Mac- it works great and intuitive. Just a click on a button and I have got the solution instead of difficult commands or something like that. Great!
