Highlighting Item
POUJOL Yves
Highlighting Item
Post by POUJOL Yves » Sun May 17, 2020 11:40 am
I would like to find for instance a caracters string in a complex drawing, highlight it and focus the window on the string. I didn't find how to do that in the reference manual of QCAD.
Thank you for your help.
Yves POUJOL.
Re: Highlighting Item
Post by CVH » Sun May 17, 2020 1:06 pm
I am not aware of such a function in Qcad.
Then again you could use the 'Selecion Filter' for that.
Tried it and it works.
Qcad Pro
Selecion Filter vissible, if not enter command 'GF'.
You can look for text entities or text based entities (eg. including dims).
The property would be the text itself.
Comparison mode and value of your choise.
4 different selection modes. (Icons)
Leave the 'Selecion Filter' widget as it is or dock it.
It is a very powerfull selection feature.
Simple as cake.
POUJOL Yves
Post by POUJOL Yves » Tue May 19, 2020 7:13 pm
Hi CVH,
Thank you for your answer.
It is not as simple as a cake :
I tried the Selection filter.
Indeed, the function find the text item and highlight it.
But, it doesn't focus the display window on the item.
So it is useless, if you don't know the position of the item.
Perhaps it is a way to memorise the position of the item and move the cursor or the display window onnt he item. But i didn't succeed unveilling such a function.
Best regards.
Yves.
Version :
3.23.0.0 (3.23.0)
Internet :
QCAD.org
Date de fabrication :
Jul 18 2019
Révision :
42e52bf
Qt Version :
5.5.1
Architecture :
x86_64
Compiler :
MSVC++ 12.0 (2013)
Windows 10.
Post by CVH » Tue May 19, 2020 7:21 pm
Selected with the filter?
Or simply selected?
What about zoom to selection?
