Block reference points
tdwyer
Post by tdwyer » Mon May 18, 2020 7:49 pm
I've created a block (a square with a criss-cross in it) with a reference point in the lower left corner. I've mirrored this such that there is a gap between the two blocks. I want to measure the distance between the two blocks, but, there are no reference points other than in the one corner. And I can't snap to those reference points. Is there a way to snap to these corners or other control points of the block elements? I could explode the block, but that defeats the purpose of using blocks. See the attached drawing.
Windows 8, QCAD 3.24.3.0
Question1.dwg
(22.64 KiB) Downloaded 35 times
Re: Block reference points
Post by andrew » Mon May 18, 2020 8:44 pm
The blocks have been inserted on layer "Dims_Detail". Layer "Dims_Detail" has its attribute "Snappable" set to "No", in other words, snapping is disabled for that layer.
tdwyer
Post by tdwyer » Mon May 18, 2020 10:25 pm
Excellent! Thank you very much.
