Viewport Scales on a drawing
Iharch
Post by Iharch » Fri May 22, 2020 11:37 am
I have placed a number of viewports onto a drawing but I would like to have each at a different scale. When creating VP's I use the 'scale' drop down list but the options are limited. How can I add different scales to this list?
Many thanks,
Iharch
Screenshot 2020-05-22 at 11.31.15.png (34.84 KiB) Viewed 329 times
Re: Viewport Scales on a drawing
Post by andrew » Fri May 22, 2020 3:47 pm
You can type any value into this box or change the scale later using the property editor (View > Property Editor, select viewport, change property "Scale".
Iharch
Post by Iharch » Fri May 22, 2020 10:17 pm
Ah yes, that worked, thank you! :D
