Draw a line a specific length
clocey
Post by clocey » Fri May 22, 2020 10:45 pm
Or how do I draw a line a specific length without depending on grid snaps?
Re: Draw a line a specific length
Post by Husky » Sat May 23, 2020 12:23 am
Launch a line tool and use the option box to fill in the specific length of the line.
petevick
Post by petevick » Sat May 23, 2020 10:41 am
you could also use the 'Line from 2 Points', snap to geometry point for the start, move the cross hairs to hover over a known snap point, press the spacebar to make tha command line active, type in the length required and press Return.
Pete Vickerstaff
Linux Mint 21.2 Cinnamon, Qcad Pro 3.29.6
