Auto-orientation
louis
Auto-orientation
Post by louis » Wed Jun 03, 2020 4:43 pm
I would like to know if we can make an auto-orientation from a dwg file to pdf file.
With command line, I used --auto-orientation, but the orientation was the same. The drawing is inclined and I would like it to be straight.
If anyone has the answer I would be thankful
Debian 10
QCAD version 3.22.1
DWG file below
menuire.dwg
(149.58 KiB) Downloaded 38 times
Re: Auto-orientation
Post by andrew » Wed Jun 03, 2020 4:53 pm
"Auto orientation" refers to the paper orientation (landscape for drawings that are wider than tall, portrait otherwise). The drawing is not rotated or changed in any way by this option.
louis
Post by louis » Thu Jun 04, 2020 8:06 am
Ok thanks for your answer, so there is no option to do this ?
Post by andrew » Thu Jun 04, 2020 8:27 am
No, there's no option to rotate or otherwise change the drawing in dwg2pdf.
If it's an option to do it manually, you could create a layout block with a viewport that displays the rotated drawing (angle 119.534361, scale 0.005):
Screenshot 2020-06-04 at 09.25.17.png (107.66 KiB) Viewed 316 times
This way you don't have to change the drawing and you can still display / print / export it straight.
louis
Post by louis » Thu Jun 04, 2020 8:33 am
OK thanks !
