[SOLVED] dwg2pdf: export sheets (layouts, paper spaces)
Posted: Tue Jun 09, 2020 8:28 am
I expected a weird behaviour on QCAD vs Autodesk. I have a DWG file and I uploaded it on Autodesk online, on ontodesk we can see diferents models and sheet (img1) but when I open the file with QCAD I have only the plan. Why ?
Can we export the same data (sheet + plan) ?
If anyone has the answer I would be thankful
Debian 10
QCAD version 3.22.1
The ZIP file contains many screenshot and the DWG file
If you want to check on autodesk: https://viewer.autodesk.com/designviews
Debian 10
QCAD version 3.22.1
