Remove all dimension entities
louis
Post by louis » Thu Jun 11, 2020 8:32 am
I would like to remove all arrows with dimension from my DWG (bottom).
See DWG file and a screenshot below. Do you have any idea how to do this with command line ? Which option ?
If anyone has the answer I would be thankful
Debian 10
QCAD version 3.22.1
ANGLET Ensemble des niveaux RDC à R+7.dwg
(1.79 MiB) Downloaded 68 times
Capture d’écran du 2020-06-11 09-31-07.png (117.37 KiB) Viewed 854 times
petevick
Re: Removed arrow with dimension
Post by petevick » Thu Jun 11, 2020 9:26 am
from the menu Edit>Drawing Preferences click on Dimension Settings in the dialog box, then set the Arrow size field to 0, click on Apply
Pete Vickerstaff
Linux Mint 20.0 Cinnamon, Qcad Pro 3.25.2.4
louis
Post by louis » Thu Jun 11, 2020 9:46 am
Thanks but I would like to remove the dimension (line, arrow, value). I try to set all value to 0 but the line are always visible
Post by andrew » Thu Jun 11, 2020 9:50 am
Just to be clear: are you looking for a way to remove (delete) all dimension entities from the drawing?
louis
Post by louis » Thu Jun 11, 2020 9:51 am
Yes
louis
Yes
Post by andrew » Thu Jun 11, 2020 9:56 am
View > Selection Filter
Choose "Dimension" as type and click the button at the bottom left to select all dimension entities:
Screenshot 2020-06-11 at 10.54.29.png (40 KiB) Viewed 835 times
Then hit the Delete key or choose Edit > Delete.
Post by Husky » Thu Jun 11, 2020 9:58 am
@louis
Please note that QCAD is a 2D program. Your drawing has Z values all over the place. I assume it is converted from a 3D drawing.
I recommend to clean the drawing from all Z-values before you put more work in it with QCAD.
louis
Re: Remove all dimension entities
Post by louis » Thu Jun 11, 2020 10:07 am
Ok thanks, so I think it's impossible to do that with command line ? Or to keep all layer expect layer with name X or Y ?
I'm sorry I'm a developper I don't have any skills with this software, be understanding with my strange question
Post by andrew » Thu Jun 11, 2020 10:12 am
Not out of the box. Using the QCAD script interface, you would have to create a command line tool that does that.
See also:
https://www.qcad.org/en/tutorial-comman ... ol-scripts
louis
Post by louis » Thu Jun 11, 2020 10:17 am
Ok thanks for your answers !
Post by CVH » Thu Jun 11, 2020 10:47 am
Has this question relevance with removing all dimensions (167 on rdc-cotation).
Then I would:
Freeze layer 'rdc-cotation'
or
Delete layer 'rdc-cotation'
louis
Post by louis » Thu Jun 11, 2020 4:24 pm
Yes I see but I need to used command line
Post by CVH » Thu Jun 11, 2020 7:02 pm
... remove all ... dimension from my DWG (bottom).
For one single file?
