dwg2pdf generates blank PDF file
vadnart
Post by vadnart » Tue Jul 07, 2020 4:03 am
(apologies if this is duplicate post)
Newbie question....i'm trying to convert DWG to PDF using the dwg2pdf command line tool (mac OS) but the resulting PDF file is blank, only 1KB in size.
I'm just using the default command without any parameters.
I am able to convert to a JPG and PNG using the dwg2bmp command and the DWG loads properly in QCAD app so i think the DWG file is ok.
I've attached the DWG file. thanks again in advance for any help.
Regards
TX0357-library.dwg
(722.91 KiB) Downloaded 303 times
J-J
Moderator
Re: dwg2pdf generates blank PDF file
Post by J-J » Tue Jul 07, 2020 6:00 am
hi vadnart,
Is that what you want?
TX0357-library.pdf
(202.7 KiB) Downloaded 411 times
Just did a print preview, autofit to page and clicked on pdf..
JJ Win7 pro-64
vadnart
Post by vadnart » Tue Jul 07, 2020 4:11 pm
Hi J-J,
Thanks! yes that's exactly what I needed. I used the -a parameter as you suggested and that works great.
thanks again.
