I'm new to QCAD - so far it's great, found my way around quite easily (previously used DraftSight - QCAD significantly easier/better).
One frustration - if I have a e.g. a line with a dimension and then move or extend the line, the dimension doesn't move or adjust with it.
Is this how it is or am I missing something??
Thanks!
Windows 10 Pro-64
QCAD Pro 3.24.3.0
Moving dimensions with objects
Re: Moving dimensions with objects
The dimension and the measured part are two distinct entities.
Select the dimension.
Each reference point can de reset, dragged or whatever.
Maybe 'Stretch' can help you when altering parts of a drawing.
