(Solved) Print only one viewport
Roberto Vid
Post by Roberto Vid » Sat Oct 24, 2020 2:34 pm
I have a layout, where I have four viewports, would I be able to print only one viewport? If so, it would be possible to explain.
Regards
Roberto Vid
Re: Print only one viewport
Post by Roberto Vid » Sat Oct 24, 2020 3:20 pm
A photo of the layout with viewports.
Regards
Post by Husky » Sat Oct 24, 2020 8:56 pm
No. All Viewports in your layout will be printed.
If you need to have only one Viewport printed create a layout with only one viewport.
If you need to have a different variants of one existing Layout I would create a new Layout and copy and paste everything from the first Layout into the new one. Not ideal but it works ... :wink:
Roberto Vid
Post by Roberto Vid » Sun Oct 25, 2020 12:04 am
Hi Husky,
Thanks for the quick response. I will do this.
Regards
