I have difficulties with the aligning tool. I want align a rectangle within a line. The center of the rectangle should be on the line.
How to do that?
Regards
QCAD Professional
Version: 3.25.2.0 (3.25.2)
Build date: Sep 4 2020
Revision: 4a61501
Qt Version: 5.13.2
Architecture: x86_64
[Solved] Aligning
[Solved] Aligning
- 2020-12-23_0.jpg (15.38 KiB) Viewed 3828 times
Re: Aligning
Post Repudiated
Re: Aligning
Line moved to rectangle ...
... Rectangle moved to line.
Hmmm, likely I would use "Align Reference Points"
Re: [Solved] Aligning
@Husky
Great example! THX
Great example! THX
